  • #22744
    How do I reduce the padding in the container-fluid boldgrid-sections?  Using the inspector in Firefox it shows padding is set to 70px 0 150px 0.  This leaves a huge blank space in the webpage.
    #22745
    JohnPaul B
    Member
    Hello KLynn,
    Thank you for contacting us about reducing padding between blocks. Often, you can use the BoldGrid Post & Page builder to adjust the sizes of the blocks and this can often reduce the padding between. Since you are custom-coding changes to your site here are some helpful links to our guide on How to use the Custom CSS Editor, and How to Create a Child Theme to Customize Your WordPress Website.
    We are happy to help you troubleshoot further, but will need some additional information. Can you provide a link to your site for us to test? What theme are you using?
    Thank you,
    John-Paul
  • The topic ‘How to reduce padding between blocks.’ is closed to new replies.
