- November 16, 2020 at 4:16 pm #31464
Wendy
GuestHi.
After a few days of building a site using BoldGrid, I’m now finding my way around much better and am able to sort all the issues that arise, as well as save a great deal of time over doing it the old-fashioned way. Great plugin guys! Thanks!
All the issues except one, that is. I have a mirror version of the site in another language. I want to be able to select a different primary menu to display in the header section for the second language pages (obviously doesn’t make sense to have a menu in a different language to the pages). Since I can’t find a way to get at the html code for the header section, please can you tell me how I might go about this?
November 16, 2020 at 4:23 pm #31502Jesse Owens
KeymasterHi Wendy-
Probably the best way to accomplish this is with a plugin like Polylang (free) or WPML (commercial, but affordable and really easy to use) to allow you to make language “versions” of your site. Both of those plugins will allow you to translate your menu so that you’re still using the same menu, but it will show in the right language on the right pages.
November 18, 2020 at 2:41 pm #31547Wendy
GuestJesse you guys really do go above and beyond because this was a stupid question which I realised the answer to after I’d posted it. But your recommendation saved the day as I was struggling with some of the other plugins which came up in my search in the meantime (Polylang didn’t). Thank you so much once again!
November 18, 2020 at 2:42 pm #31558Jesse Owens
KeymasterHappy to help as always Wendy! Glad to hear it.
- The topic ‘[Resolved] Hydra: Alternate primary menu in header section for language mirrors’ is closed to new replies.
