  • #22625
    I am using Plesk Onyx, and installed Bold Grid From extensions, How can I now install trial license key/connect key from Onyx panel
    #22626
    Arnel C
    Member
    Thanks for your question about the key. Typically, when you install BoldGrid (after installing WordPress) you will be prompted to add the key. You can obtain a key by logging into BoldGrid Central. You can also manage the key options in the actual interface itself. For more information, please read through How to Install BoldGrid via the Plesk Onyx 17 Web Admin.
    If you have any further questions or comments, please let us know.
  • The topic ‘I am using Plesk Onyx, and installed Bold Grid From extention, How can I install trila license key from Onyx panel’ is closed to new replies.
