  • #52267
    Elizabeth H. Keegan
    Hi I configured an inspiration general website design for infinite scrolling, but i’d like to change that to distinct pages. Can you help? Thanks, Beth
    #52622
    Hi Elizabeth!
    Thank you for reaching out and thanks for using Crio Pro WordPress theme!
    The good news is if you’ve already successfully deployed your BoldGrid Inspiration you’re more than half way there to setting up your WordPress theme!
    Now, the question is, would you like to modify the pages that were already configured by BoldGrid Inspirations, or do you want to start from scratch and create completely new pages and posts? It’s really up to you and the auto generated blocks in BoldGrid Post and Page Builder will make your life much easier.
    If you need to create a “new page” or “post” you can do so from the WordPress dashboard under the “Add Page” or “Add Post” sections. You can change global elements of in website from the WordPress Customizer. Appearance < Customize. We’ve loaded the customizer with over 400 customization tools that are available to you to use at your disposal.
    You have the ability to adjust your menus, page headers and footers, site content, blog layout and more. My suggestion is to start with the pages and posts provided by Inspirations and try modifying them to achieve the look you desire. You can always wipe all the content on any page and start completely from scratch.
    We can help with your next steps, we just need you to let us know which approach you would like to take. It would also be a great help if you could link us to the URL of your website so that we can inspect it directly, that way we can give your our best and most sure suggestions on how you should proceed.
    I hope I’ve answered some of your questions. We look forward to assisting you further with this!
    • This reply was modified 2 years, 10 months ago by Brandon C.
  • The topic ‘I need help modifying my BoldGrid Inspiration’ is closed to new replies.
