- January 4, 2022 at 9:16 am #46541
Heather M Spencer
GuestHi,
I’m not sure if this is something you can help me with, but I have my fingers crossed. I just added a plugin to allow customers to save products to a wishlist. The plugin is WPC Smart Wishlist for Woocommerce.The first issue is how the ” Wishlist” page is displaying on a mobile device. The link to that page is https://momentofperception.com/wishlist/
You’ll need to add a wishlist item of course to see the problem.The second issue concerns the order of the main menu. The plugin inserted the Wishlist at the end of the main menu, and I would like to move it, but it’s not showing up on any of my menu editing areas.
Thanks for any help.
Best,
HeatherJanuary 4, 2022 at 12:14 pm #46641Brandon C
ParticipantHi Heather,
Thanks for reaching out and thanks for using the Cobalt theme with BoldGrid Post and Page Builder for WordPress!
I tried adding a Wishlist item and was unable to. Whenever I went to open the Wishlist link no item would populate. Is that the issue you were speaking of or was it a totally different issue altogether?
In regards to your Main Menu, you should vist the Menu section of your WordPress dashboard and create a custom menu link for the Wishlist URL if you would like to display it in your header menu. Be sure to save your menu updates after you finish your edits.
I recommend reaching out to WishList directly for any plugin related issues. I’m not sure how good there support is but they should be able to offer some guidance on how to setup your WishList items.
I hope this helps. Please let us know if you have any other questions.
- The topic ‘I’m having Issues with WPC Smart Wishlist Plugin’ is closed to new replies.
