  • #151086
    Sarah Vigue
    Hi
    Is there a format painter in bold grid? If so, where is it and how do I access it? I can’t find it or anything like it to make editing in the tool any easier and my website is in development so I need to know.
    Sarah
    #151180
    Hi Sarah,
    Thanks for reaching with your BoldGrid Post and Page Builder questions.  Post and Page Builder does not include a specific “format painter” tool like you might find in desktop applications such as Microsoft Word. However, you can easily replicate or apply consistent formatting using the page builders functionality:
    Tools for Consistent Formatting in BoldGrid:
    1. Block Duplication:
      • If you want to replicate a specific style, you can duplicate an entire block or section and edit the content while keeping the formatting intact.
      • To duplicate a block:
        • Hover over the block you want to copy.
        • Click the three-dot menu (block options) and select Duplicate.
    2. Custom CSS Editor:
      • If you need precise formatting control across your site, you can apply global styles through the Custom CSS Editor.
      • Access it via Appearance > Customize > Additional CSS in the WordPress dashboard.
      • You can define consistent styles for elements such as headings, paragraphs, or buttons.
    3. Preset Styles for Text:
      • The BoldGrid Post and Page Builder provides pre-set formatting options for headings, text, and buttons in the editor toolbar. Use these instead of manually styling elements each time.
    4. Reusable Blocks:
      • If you frequently use the same formatting or content, save a block as a Reusable Block.
      • To save as reusable:
        • Select the block.
        • Click the three-dot menu and select Add to Reusable Blocks.
        • Name the block for future use.
    5. Theme-Level Global Settings:
      • Use BoldGrid’s Crio SuperTheme or another BoldGrid theme to set up global font, color, and spacing options for your site.
      • Navigate to Appearance > Customize > Fonts or Colors to ensure a unified design.
    Alternate Workflow for Faster Formatting:
    • If you find applying formatting in the editor cumbersome, you might want to format content in an external tool and then paste it into the builder while using the “Clear Formatting” option in the toolbar to clean up unnecessary styles.
    I really hope this helps. Let us know if you have more questions for us!
  • The topic ‘Is there a format painter in BoldGrid Post and Page Builder?’ is closed to new replies.
