The easiest way may be to clone the column with the width you like three times. Then you would have three equal columns to edit. You can leave the left and right columns blank and fill the the middle column with text. Or, you can add images and other content to the left and right blocks.
A design grid on my site has three columns that do not stretch the entire width of the site. Instead of dragging the columns and making them wider to fill the entire site width, I would like to center them in the middle of my site with equal space left on either side. How can I do this?
Thank you for your help!
Author
The topic ‘Issue with centering columns’ is closed to new replies.
