  • #22930
    I’m setting up a prototype site for a client and and when I made the menu it used a WP icon instead of the page title.
    I looked through the info , but couldn’t find any solution.
    prototype location:
    http://spirit.boulderwordpress.com/
    Hi Larry!
    Thanks for posting your question regarding the WP icon appearing in place of your menu’s text. I’m sorry to see that you are experiencing difficulty with this. I have reviewed your site and it appears there is a plugin that is manipulating the way menus are displayed. BoldGrid, by default, will not use icons as menu items. Are you able to provide some more details in regards to how you developed/created those menus? With those details, I may be able to further assist you.
    Best Regards,
    Carlos D
  • The topic ‘Issue with icon instead of text for primary menu’ is closed to new replies.
