- July 28, 2020 at 12:06 pm #25416
Stephen
GuestJuly 28, 2020 at 12:15 pm #25424Jesse Owens
KeymasterHello Stephen-
Yesterday we released an update to Post and Page Builder that should, at least, resolve the error in your third screenshot. Can you update to the newest version and let us know if the errors continue?
July 28, 2020 at 1:43 pm #25429Stephen
GuestI am on version 1.13.2, which appears to be the latest. However, I am still seeing the same issue at login.
July 28, 2020 at 1:43 pm #25441Jesse Owens
KeymasterThanks for confirming that. We did get one other report about this issue, and we’re working on a fix now. I’ll update you here as soon as we’ve got an update for you.
July 29, 2020 at 1:27 pm #25466Stephen
GuestThank you for the follow up Jesse. Any insights into the other two issues? Is it possible to disable the NewsWidget?
July 29, 2020 at 1:48 pm #25468Jesse Owens
KeymasterHi Stephen-
While working with the other user who’s experiencing this issue, we found out that there’s a connectivity issue between their hosting account at DreamHost and the BoldGrid servers.
If you have SSH access to your hosting account, can you run the following commands from your server to see if you’re having the same issue?
ping -c 10 boldgrid.com
and
traceroute boldgrid.com
DreamHost is currently investigating the connectivity issues for a permanent resolution. In the meantime, yes you can disable the widget using the plugin Widget Disable.
July 29, 2020 at 5:59 pm #25472Jesse Owens
DreamHost just reached out to us to let us know that the connectivity issue has been resolved. Can you confirm that all your errors have disappeared?July 30, 2020 at 12:18 pm #25477Stephen
GuestHi Jesse. Yes, it looks to be working much better. Thanks for the quick responses on the issue!
August 3, 2020 at 12:24 pm #25553Stephen
GuestHi Jesse — Looks like those same issues are happening again this morning. I am getting the PHP error and HTTP API Calls related to Bold Grid and the NewsWidget. Thank you.
August 3, 2020 at 2:14 pm #25566Jesse Owens
It looks like DreamHost’s internal firewall system has blocked the API calls again. We’re working with them to get these whitelisted ASAP. I’ll update you here as soon as I hear back. - AuthorPosts
- The topic ‘Issues on WP Admin login’ is closed to new replies.
