Viewing 5 posts - 1 through 5 (of 5 total)
  • #79373
    ali
    I can’t figure out why the second column, which contains the gallery images, won’t appear to the right of the main column, and instead appears below it.
    Any help is greatly appreciated!
    https://65b2f2dd2210090413.temporary.link/catering/
    #79377
    Hi Ali,
    Thanks for reaching out, we’re inspecting your Crio Pro WordPress theme and I see you have the gallery column positioned to the left of the page with the content towards the right.
    I’m not noticing the issue you spoke of initially with the gallery positioned to left, but I’m wondering if this was your desire or are you still having issues positioning the gallery to the right of your text?
    We look forward to hearing back from you. Your concern sounds very similar to an issue that we are currently researching so I will definitely keep you in the loop while we’re working on a solution!
    #79517
    ali
    I had moved the gallery to the left, to see if that would fix the issue. It did not, so I edited the code to adjust the number of columns that the gallery took. It appears that the main content was usinng the full 12 bars available, and that caused the gallery to appear above or below. Once I manually changed the number of bars, I was able to get the two columns to appear side-by-side.
    But there should be an easy way to set the column width, in the wysiwyg editor, but I for the life of me could not figure it out.
    #79518
    ali
    Also, I can’t figure out how to control the spacing between images here: https://65b2f2dd2210090413.temporary.link/catering/
    #79814
    Thanks Ali,
    We’re going to have to set this up on our end and test a bit. Ideally you should be able to set this up using a block component in the PPB editor or a pre generated BoldGrid block.
    It may be as simple as nesting the content of your columns inside the same section and row. If we can replicate this error we’ll get a feature request in right away to correct it.
    As far as your issues with spacing you should be able to hover over your image and select the blue “Column” icon – Advanced Controls, and control margin and padding elements for that particular column from there.
    You could also modify the spacing between your images using custom CSS in the WordPress customizer. We can definitely help with this if you can let us know exactly what you’d like to do.
  • The topic ‘Issues with Column Placement in BoldGrid Post and Page Builder’ is closed to new replies.
