  • #70152
    Arthur Jumper
    Master Slider does not load after selecting the name. my workaround is to create a new master slider each time, then edit short code [masterslider id=”9″].
    I used to be able to edit the master Slider rather than create a new one each time.
    #70169
    Hi Arthur,
    Thanks for your question. This support site is specifically for BoldGrid products such as Crio Pro WordPress theme and BoldGrid Post and Page Builder for WordPress.
    I’m not too familiar with the Master Slider Plugin and I see you’re using the TwentyThirteen WordPress theme. My suggestion here is to make sure that your theme and all plugins are up to date and there are no relevant errors in the console.
    You should try reaching out to the plugin developer directly. I found a support forum for them on wordpress.org.
    You should be able to get further assistance there. I hope this helps!
  • The topic ‘Master Slider plugin will not load after selected on TwentyThirteen WordPress theme’ is closed to new replies.
