- January 6, 2017 at 1:22 pm #24040
admin
MemberHello Esh,
Thank you for your question regarding hiding the mobile menu button in the Grid One theme. Please keep in mind that this theme was not designed with this option in mind. However, if you open the Customizer, go to the Advanced tab, and then select the Custom JS & CSS. From there, under ‘Custom Theme CSS’ click Open Editor, make a new line, and then paste the following CSS rule:
button.navbar-toggle{ display: none }Gratefully,
Casey B.
January 6, 2017 at 7:40 pm #24039Esh Qa
MemberOh my gosh, Casey, thank you, thank you, thank you!!!!! It worked!!!!!! 😀
I soooo appreciate you having taken the time to tell me what to do!!! Grid One is my favorite theme but the drop down menu with the background looked too heavy for how I have the website.
Happy New Year and take very good care!
Very Gratefully,
Sherry (Esh Qa)
July 20, 2017 at 3:13 pm #24038Anonymous User
MemberI’ve used the Max Mega Menu plugin to make a drop down menu without a background but I don’t know where to remove the Grid One theme mobile menu button so I can publish the new Max Mega Menu. I would so appreciate if someone can tell me where to remove it. ?
- The topic ‘Max menu plugin issue’ is closed to new replies.
