  • #70534
    Alex Z
    Hi BoldGrid team
    I am seeing this error after installing total upkeep premium
    Fatal error: Declaration of Monolog\Handler\StreamHandler::write(array $record) must be compatible with Monolog\Handler\AbstractProcessingHandler::write(array $record): void in /var/www/vhosts/jdmis.edu.sg/learn.jdmis.edu.sg/public/wp-content/plugins/boldgrid-backup-premium/vendor/monolog/monolog/src/Monolog/Handler/StreamHandler.php on line 92
    There has been a critical error on this website.
    Could you advice on a possible cause?
    Last time we saw something like this it was due to an outdated guzzle implementation in total upkeep and you fixed it very quickly! Have you any suggestions on how we can get to the bottom of this?
    Thank you
    Alex
    #71009
    Hi Alex,
    Thanks for reaching out with your Total Upkeep questions! Sorry to hear you’re having a bit of trouble but if you could visit your “Plugins” dashboard and copy/paste the list of active plugins here in the forum we can try replicating the issue on our end get a bug ticket in for a version update if need be.
    You can also try deactivating all plugin with the exception of BoldGrid related plugins to test the issue. If it does not occur with only BoldGrid plugins active try activating the remaining plugins one by one until you find the problematic plugin.
    We look forward to assisting you further with this!
  • The topic ‘Monolog conflict with Boldgrid Total Upkeep Premium’ is closed to new replies.
