  • #47514
    Tim Burkart
    Hello!
    Now that I have upgraded to PRO I no longer see the option to move CSS to the body. Does that happen automatically now? Otherwise, where can I find the option?
    Thank you
    #47556
    Hello Tim
    The option to “Eliminate render-blocking CSS by moving it to HTTP body” is only available after upgrading to W3 Total Cache Pro.
    The option is greyed out if you are using the community version of the plugin.
    Once the Pro is enabled, that option is available. Please note that only minified CSS files can be processed with this option.
    CSS minify settings
  • The topic ‘Move CSS to body’ is closed to new replies.
