  • #86335
    Anne Chesky
    We have Crio on ashevillehistory.org but accidentally deleted the code in the header.php – Can you help?
    #86352
    Hi Anne,
    Thanks for reaching out with your Crio Pro WordPress theme questions!
    If you deleted template files by mistake you can simply download the Crio WordPress theme again from the WordPress Repository and reinstall it on your site and it will restore all code that was removed.
    We recommend using a plugin like Code Snippets to modify code instead of editing template files directly, that way you won’t lose any of your edits when the theme is updated.
    I hope this helps. Please let us know if you have any other questions for us!
  • The topic ‘Need help with Crio WordPress theme header’ is closed to new replies.
