- November 16, 2023 at 12:48 pm #116807
Himanshu Gupta
Guesti’m planning to buy W3TC Pro plan but this plugin not working properly in my website as you see video thumb and footer part is not showing on homepage.
November 16, 2023 at 12:50 pm #116812Marko Vasiljevic
KeymasterHello,
Can you please disable the settings one by one in W3 Total Cache Performance>general settings, save the settings and purge the cache after each setting is disabled and see which one might be causing the issue?
November 17, 2023 at 11:36 am #116827Himanshu Gupta
Guestyeah, its causing by the Minify so how can i fix this ?
November 17, 2023 at 11:57 am #117055Marko Vasiljevic
KeymasterHello,
If the issue is gone, re-enable minify, and disable the settings in Performance>minify one by one (HTML minify, JS minify, CSS minify) and see which one might be causing the issue.
Make sure to save all settings and purge the cache after each option is disabled.
Thanks!November 21, 2023 at 11:35 am #117859Himanshu Gupta
Guestits causing by HTML & XML minify option, so what i do to fix it ?
- The topic ‘plugin having issue with thumb and footer’ is closed to new replies.
