  • #50985
    Jessica Carson
    I am using Post and Page builder to edit my Ibtana/VW Consulting Gutenberg Theme. It has taken 8 hours to make very simple changes. The first four was trying to get it to show on the live page after publishing. The editor and live page do not seem to be in sync. Now, for the last four hours, it takes 10 minutes for the full page to load to edit, and after I make one edit, the page becomes unresponsive. I have not been able to edit for the last four hours. I tried adding optimization. Made worse. Removed optimizers that might be interfering, updated everything possible in plug ins and themes and WP. Disabled page cache. Nothing worked. Uninstalled the settings for the cache. Deactivated all plugins I am not using. Please help!
    #51464
    Hi Jessica,
    Thanks so much for using BoldGrid Post and Page Builder for WordPress!
    I’m sorry to hear you’re having these issues with your website performance. I ran your URL through GTmetrix and returned these results. Your performance metrics indicate problems that go beyond Post and Page Builder.
    It looks like the bulk of your issues are due to “enormous network payloads” stemming from your VW-consulting theme, and the need to reduce “intial server response time”. You normally see this with shared hosting or limited server capabilities set forth by a Webmaster. You may want to consult with Your Web Hosting Provider (DreamHost) about increasing your server resources a bit to handle more server request.
    I highly recommend reviewing through this article on optimizing WordPress. You should also consider turning on gzip – which is available in your cPanel account under Optimize Webite. Please review the recommendations of Gtmetrix for further assistance.
    Your theme also does not seem to be compatible with Post and Page builder. It appears to be clashing with Post and Page Builder because they use two completely different frameworks and both frameworks are attempting to add attributes to the same elements.
    I’d recommend if possible switching to Crio Pro WordPress theme with is our flagship WordPress theme and 100% compatible with Post and Page Builder. Your Web Hosting provider DreamHost is one of our premium partners so Crio Pro is available to you free of charge.
    I hope this helps. Please reach back out if you have any other questions for us.
  • The topic ‘Post and Page Builder unresponsive with my Ibtana/VW Consulting Gutenberg theme’ is closed to new replies.
