We are using the Post List bold grid component in our page/post using Post and Page Builder (wp_boldgrid_component_postlist). We are on Dreamhost which has the premium version of post and page builder.
How can we increase the limit from 50 to 100 as we would like to avoid breaking into multiple pages/posts
You’re right that the up/down arrow control on the post list settings maxes out at 100, but you can simply use the keyboard to replace that number with 100.
As long as you don’t try to change the number with the arrows again, the new setting for Max Posts will stay at whatever number you used.
Ha Ha..typing inside the box did not cross my mind… I thought we tried that and was not working…but I will give that a shot else I found where that setting is worst case if I have to change the php file where the max is set to 50 (PostList.php)
Ok to close this issue.
Author
The topic ‘Postlist component max allowed is only 50 posts and need to increase’ is closed to new replies.
