- January 23, 2017 at 8:55 am #24639
MemberHello,
After updating (I dont remember name of plugin), my page colors are not working correctly — like on buttons. I dont know why. Should I delete the plugin? Or can I customize colors?
For example:
<code class="language-html"> <span class="nt"><button</span> <span class="na">type=</span><span class="s">"button"</span> <span class="na">class=</span><span class="s">"btn btn-danger"</span><span class="nt">></span>Action<span class="nt"></button> this button is <strong>red color</strong>, but in my page is <strong>violet</strong>. I can set any color, but my page always show me just violet and green color. I dont need how create buttons, or how change color of page.. I dont wanna change color of my background. When I set </span></code><strong><code class="language-html"><span class="s">"btn btn-danger" </span></code></strong><code class="language-html"><span class="s">- need be <strong>red</strong></span></code><code class="language-html"><span class="s"><strong>! <u>Why my page always show me violet???</u></strong> I set any plugin wrong, but I dont know which one. OK? Hope you understand what I mean. I just need to check what I doing wrong. Before this plugin always work tip-top. Always was udjusting ok, just after any plugin start some problem for me. How can I or you check which plugin start this problems???? I am not happy with all your help and always send me link for seting page. Just need check which one is wrong. Thats all. </span></code>
my page : redballblue.com
Thank youViera
January 23, 2017 at 11:59 am #24640admin
MemberHello Viera,
Sorry to hear you are having issues with your button colors in BoldGrid. I am not sure what you had going on previously. Can you give more details on how you have the button colors changing? In researching this theme, the button color is tied to the same as the header background color, so if the header area is purple, then so is the button.
Were you using a third party plugin that allows you change the button color individually?
Kindest Regards,
Scott M
- The topic ‘Problem With Button Colors After Installation’ is closed to new replies.
