- The topic ‘problem with images’ is closed to new replies.
Hi, i realized a better version of the website with more nice look with elementor. the question is that with you plugin the images codul be not correct.
for example test pls this page with and without your plugin https://www.ipnosiviteprecedenti.it/regressione-vite-passate/ where u leave color and parts and will be only orrible black parts.
waiting a solution, regards.
I am sorry about the issue you are experiencing with the images and I am happy to assist you with this.
Can you please disable the settings one by one in Performance>general settings, save the settings and purge the cache after each setting is disabled and see which one might be causing the issue?
