- April 3, 2023 at 11:48 am #84491
Lori Corbett
GuestHi, I’m testing the free version of Total Upkeep before I buy (client site). When I started the backup, it backed up the database, then hung. The first line of the log tells me:
Cannot add signal handlers, pcntl_async_signals function does not exist
Here is the complete log:
[2023-04-01 20:31:42 UTC] Cannot add signal handlers, pcntl_async_signals function does not exist.
[2023-04-01 20:31:42 UTC] Last error: Array
[type] => 2
[message] => file_get_contents(/home/georgezz/boldgrid_backup/logs-53fb8209-a31a790f95784dd2/archive-1680381102.log): failed to open stream: No such file or directory
[file] => /home/georgezz/public_html/wp-admin/includes/class-wp-filesystem-direct.php
[line] => 39
)[2023-04-01 20:31:42 UTC] Backup process initialized.
[2023-04-01 20:31:42 UTC] Process id: 5977
[2023-04-01 20:31:42 UTC] ——————————————————————————–
[2023-04-01 20:31:42 UTC] Starting dump of database…
[2023-04-01 20:31:42 UTC] Memory usage – limit / current / peak memory usage: 1024M / 21850656 (20.84 MB) / 23895400 (23 MB)
[2023-04-01 20:31:42 UTC] Database info: Array
[wp_7jz6q9sn3b_actionscheduler_actions] => 18
[wp_7jz6q9sn3b_actionscheduler_claims] => 0
[wp_7jz6q9sn3b_actionscheduler_groups] => 2
[wp_7jz6q9sn3b_actionscheduler_logs] => 54
[wp_7jz6q9sn3b_adrotate] => 146
[wp_7jz6q9sn3b_adrotate_groups] => 13
[wp_7jz6q9sn3b_adrotate_linkmeta] => 257
[wp_7jz6q9sn3b_adrotate_schedule] => 95
[wp_7jz6q9sn3b_adrotate_stats] => 132957
[wp_7jz6q9sn3b_adrotate_stats_archive] => 0
[wp_7jz6q9sn3b_adrotate_tracker] => 7162
[wp_7jz6q9sn3b_ai_statistics] => 3947
[wp_7jz6q9sn3b_cleantalk_ac_log] => 3487
[wp_7jz6q9sn3b_cleantalk_connection_reports] => 0
[wp_7jz6q9sn3b_cleantalk_no_cookie_data] => 0
[wp_7jz6q9sn3b_cleantalk_sessions] => 0
[wp_7jz6q9sn3b_cleantalk_sfw] => 16301
[wp_7jz6q9sn3b_cleantalk_sfw_logs] => 145
[wp_7jz6q9sn3b_cleantalk_spamscan_logs] => 0
[wp_7jz6q9sn3b_cleantalk_ua_bl] => 64
[wp_7jz6q9sn3b_commentmeta] => 5884
[wp_7jz6q9sn3b_comments] => 35415
[wp_7jz6q9sn3b_db7_forms] => 2733
[wp_7jz6q9sn3b_email] => 144
[wp_7jz6q9sn3b_fvm_cache] => 0
[wp_7jz6q9sn3b_fvm_logs] => 0
[wp_7jz6q9sn3b_gglcptch_allowlist] => 0
[wp_7jz6q9sn3b_links] => 7
[wp_7jz6q9sn3b_monalisa] => 17
[wp_7jz6q9sn3b_options] => 1510
[wp_7jz6q9sn3b_pollsa] => 111
[wp_7jz6q9sn3b_pollsip] => 8351
[wp_7jz6q9sn3b_pollsq] => 15
[wp_7jz6q9sn3b_postmeta] => 327241
[wp_7jz6q9sn3b_posts] => 47367
[wp_7jz6q9sn3b_term_relationships] => 29825
[wp_7jz6q9sn3b_term_taxonomy] => 2087
[wp_7jz6q9sn3b_termmeta] => 0
[wp_7jz6q9sn3b_terms] => 2087
[wp_7jz6q9sn3b_tm_taskmeta] => 0
[wp_7jz6q9sn3b_tm_tasks] => 0
[wp_7jz6q9sn3b_ultimatetables] => 2
[wp_7jz6q9sn3b_usermeta] => 556
[wp_7jz6q9sn3b_users] => 15
[wp_7jz6q9sn3b_wfBlockedIPLog] => 1370
[wp_7jz6q9sn3b_wfBlocks7] => 15
[wp_7jz6q9sn3b_wfConfig] => 305
[wp_7jz6q9sn3b_wfCrawlers] => 200
[wp_7jz6q9sn3b_wfFileChanges] => 0
[wp_7jz6q9sn3b_wfFileMods] => 18197
[wp_7jz6q9sn3b_wfHits] => 1622
[wp_7jz6q9sn3b_wfHoover] => 0
[wp_7jz6q9sn3b_wfIssues] => 33
[wp_7jz6q9sn3b_wfKnownFileList] => 18197
[wp_7jz6q9sn3b_wfLiveTrafficHuman] => 0
[wp_7jz6q9sn3b_wfLocs] => 0
[wp_7jz6q9sn3b_wfLogins] => 2000
[wp_7jz6q9sn3b_wfNotifications] => 69
[wp_7jz6q9sn3b_wfPendingIssues] => 0
[wp_7jz6q9sn3b_wfReverseCache] => 13
[wp_7jz6q9sn3b_wfSNIPCache] => 0
[wp_7jz6q9sn3b_wfStatus] => 976
[wp_7jz6q9sn3b_wfTrafficRates] => 753
[wp_7jz6q9sn3b_wfls_2fa_secrets] => 0
[wp_7jz6q9sn3b_wfls_role_counts] => 0
[wp_7jz6q9sn3b_wfls_settings] => 30
[wp_7jz6q9sn3b_wpfm_backup] => 0
[wp_7jz6q9sn3b_wpmailsmtp_debug_events] => 0
[wp_7jz6q9sn3b_wpmailsmtp_tasks_meta] => 0
[wp_7jz6q9sn3b_xmlgooglemaps] => 12
[wp_7jz6q9sn3b_xmlgooglemaps_cache] => 3
[wp_7jz6q9sn3b_xmlgooglemaps_gpxfile] => 0
[wp_7jz6q9sn3b_xmlgooglemaps_gpxfile_item] => 0
[wp_7jz6q9sn3b_yoast_indexable] => 29766
[wp_7jz6q9sn3b_yoast_indexable_hierarchy] => 29718
[wp_7jz6q9sn3b_yoast_migrations] => 23
[wp_7jz6q9sn3b_yoast_primary_term] => 1328
[wp_7jz6q9sn3b_yoast_seo_links] => 27054
[wp_7jz6q9sn3b_yoast_seo_meta] => 5977
)[2023-04-01 20:31:57 UTC] Cannot add signal handlers, pcntl_async_signals function does not exist.
[2023-04-01 20:31:57 UTC] Backup process running: Yes (pgid = 5977)
[2023-04-01 20:32:00 UTC] Cannot add signal handlers, pcntl_async_signals function does not exist.Thanks in advance for any insights you can give me.❤️
LoriApril 3, 2023 at 11:54 am #84614Brandon C
ParticipantHi Lori,
Thanks for reaching out although I’m sorry to hear you’re having trouble creating your first backup. Thanks for sending over your Total Upkeep backup log. What I get from this is the
error.It sounds like the
pcntl_async_signals
method is not enabled in the version of PHP currently running on your web server and enabling it should get rid of the error message. You might need to reach out to your hosting provider to see if that is something that they can handle for you.Hopefully making that configuration change gets the backup working correctly. You may also benefit from changing the compressor type you’re currently using to generate backup. You can find which Compressor you are using under the Backup Process settings. Try switching the Compressor to System Zip if you are not already using it to see if maybe that will get backups working.
Also, does your website pass the functionality tests in the Preflight Check tool?
- The topic ‘Problems creating a backup in Total Upkeep’ is closed to new replies.
