- April 3, 2023 at 11:55 am #84533
Lance Nelson
I’ve just installed Jetpack Boost on my Crio Premium site. It seems to have speeded up the site, and everything seems to work nicely, except for a series of odd links in the site which Jetpack Boost doesn’t like, saying that they are “redirecting to different pages.” All of them are hinduchristianstudies.org/bg-block/ … ?donotcachepage … links (see Boost’s “Critical CSS advanced recommendations” copied below).
My questions are:
(1) What are these bg-block links for? What is their function?
(2) Boost give the option, “If you think that the redirection is valid, then it is safe to ignore this issue.” Should I just ignore the “issue”?Thanks! Lance
While Jetpack Boost has been able to automatically generate optimized CSS for most of your important files & sections, we have identified a few more that require your attention.
Custom post type
These URLs are redirecting to different pages:https://hinduchristianstudies.org/bg-block/blue-horizontal-space/?donotcachepage=6637587561db1a353242be226096c7f6
https://hinduchristianstudies.org/bg-block/2020-racism-statement/?donotcachepage=6637587561db1a353242be226096c7f6
https://hinduchristianstudies.org/bg-block/call-to-action-7-2/?donotcachepage=6637587561db1a353242be226096c7f6
https://hinduchristianstudies.org/bg-block/call-to-action-7/?donotcachepage=6637587561db1a353242be226096c7f6
https://hinduchristianstudies.org/bg-block/pricing-tables-4/?donotcachepage=6637587561db1a353242be226096c7f6April 4, 2023 at 1:02 pm #84767Brandon C
ParticipantHi Lance,
Thanks for reaching out and thank you for using Crio Pro WordPress theme!
The redirects you see are completely safe, the redirect could be caused by some protocol method such as
http:// to https://
. It won’t effect your site but you may want to run an official caching plugin such as W3 Total Cache which will allow you to defer or exclude these types files altogether.I hope this helps!
- The topic ‘Questions about Crio Premium and Jetpack Boost’ is closed to new replies.
