  • #31758
    Rotem
    I have a hebrew (RTL) site that has some issue with the BoldGrid builder features,
    the advanced control window is not aligned correctly and I cannot even read or understand of is selected options as the bottom menu moved to the right side and the text is blocked.
    you can see the example window on this URL:
    https://u.pcloud.link/publink/show?code=XZy2QLXZCLTleA3YK9boe8Le45U26mFIjxXV
    I hope the fix for this bug will be quick.
    Rotem
    #31777
    Hi Rotem-
    Thanks for the report, and I’m sorry to hear about the issue using the Post and Page Builder in your language.
    I’ve gone ahead and filed a bug report to fix the RTL display, and I’ll update you here as well when we have a fix ready for this.
  • The topic ‘RTL Issues with builder’ is closed to new replies.
