- October 17, 2016 at 10:57 am #24000
admin
MemberHello SMcClure,
Thank you for your question about the edge of the previous image showing on the edge of the current image. That behavior is also there on the default images, so it is not due to your images, it is simply the default design of the gallery.Kindest Regards,
July 21, 2017 at 5:14 pm #23998Anonymous User
MemberI am working with the Bold Grid Primas Theme, and the slideshow at the top of the page shows the edge of the previous picture. I replaced the stock photos with images the exact same size. I even tried a larger size photo with the same result. Is there a way to fix this so the pictures align properly, or is this the way the slideshow works?
July 28, 2017 at 11:12 pm #23999BoldGrid Support
KeymasterI ran into this issue with this theme today. This has been taken care of and will be in the next release of the theme. In case anyone runs into this problem and references here, the image can be adjusted to the middle with CSS using the CSS tool in the customizer:
.wcflexslider-container .gallery-icon {
margin-left: -16px;
} - AuthorPosts
- The topic ‘Slideshow Shows Edge Of Previous Picture’ is closed to new replies.
