  • #34460
    Peter Bebb
    I repeatedly get the following message: The report failed to run successfully. Please try again. (Report ID: 603e2ce79f1ab83a8471622b. Error Code: WebCoach Error). How do I avoid this error?
    #34477
    Hi Peter-
    Thanks for reaching out and for using BoldGrid’s Speed Coach website performance test.
    If you’re entering your website address exactly like you did in this question, i.e. www.development.example.com, the reason the test is failing is because there is no DNS for the www. sub-sub-domain.
    Instead, enter your website address like so: development.example.com.
  • The topic ‘Speed coach error Error Code: WebCoach Error’ is closed to new replies.
