- September 22, 2016 at 1:05 pm #24818
MemberI deleted my pages in active and staging to start over before I realized there was a Start Over capability in Settings. Now when I try and use the proper Start Over procedure, I get a message that says,
You do not have a BoldGrid site to delete! You can build a new website using BoldGrid Inspirations.
When I try Inspirations, it says “We’ve recognized that you’ve already installed your Staging site. Your theme will be installed in that installation.”
The messes I created in the Staging and Active site are still there. I really do want to start over but can not seem to be able to clean out Staging and Active. Thus I seem to be in a circle I do not know how to break. How do I truly start over now?
scott11166@gmail .com
September 22, 2016 at 1:45 pm #24819JohnPaul B
MemberIt may be beneficial to completely start over by uninstalling the BoldGrid plugin and all files. Also, uninstall WordPress and the associated files. This should clear out all the instances.
Then, reinstall WordPress, and reinstall the Boldgrid plugin from scratch.
- The topic ‘Starting Over Feature Does Not Working’ is closed to new replies.
