  • #154229
    Dina Patel
    I use Boldgrid for our website and I am having issues adding an image. I click on add media and can’t even see the media files I have already uploaded and I am getting an error when trying to upload a new image. I can only add text to my sponsors page and need to add a logo which has been failing. I have been trying for days as it says try again later, but have had no luck.
    Thanks for the help.
    Dina
    #154262
    Elana
    Hello Dina,
    Thank you for reaching out to us!
    It sounds like the issue you’re encountering could be related to a few different factors, such as your PHP version, memory limits, or even an .htaccess configuration issue, or possibly a mod security.
    I recommend reaching out to your server administrator or hosting provider to check:
    • The PHP version you’re using
    • Your PHP memory limits
    • Any restrictions in your .htaccess file
    • Errors in the logs or possibly Mod Security.
    They should be able to provide more insights into what might be causing this issue. If you could reach out to them and let us know your finding we will be happy to assist where ever is needed.
    Let me know if you need further assistance or if I can help guide you through anything else!
    Elana D.
  • The topic ‘Tech issues’ is closed to new replies.
