  • #154292
    AConlon
    We have Total Upkeep installed on two websites. It seemed to work okay until last night.
    As of 10:10 pm MT, Total Upkeep has started running Backup Archives every ten minutes on both websites, which is filling up the server.
    I logged into the websites and noticed that the option in the CRON job schedule is every 5, 10, 30, or 60 minutes. I changed it to every hour, but even so, running that frequently every week will be too much for the hosting provider.
    Before last night, the backups ran just once a week, not every ten minutes (which was the default, apparently.)
    Can you please assist me? I want to keep this as a redundancy for my client, but not with these settings.
    Elana
    ​Thank you for reaching out to our support team.
    If you haven’t already, please ensure that you are using version 1.16.10 of Total UpKeep. This version should address the issue you mention.
    Also, if you are getting errors please share any errors you are getting from backups or CRON logs.
    You can check the CRON log by going to WordPress Admin → Total UpKeep → Tools → CRON Log and verify if there are multiple line items or errors being logged. If you see anything unusual there, it might explain the repeated notifications.
    If you’re still seeing the problem after checking these steps, feel free to let me know, and I’d be happy to assist you further.
    Thanks again for your patience, and I look forward to getting this resolved for you!
    Elana D.
    #154337
    A Conlon
    Hello Elana,
    I checked the steps you recommended.
    The Total Upkeep Plugin is up to date on both websites. The error has stopped now that the scheduled date has passed. I have several screenshots to share with you if there is a way for me to share them.
    The logs show no errors, per see; however, there are hundreds of pending emails generated from backups. I don’t know why they weren’t sent. Maybe my mail server blocked them as spam. (This is likely due to the overwhelming volume of mail.)
    The settings are all accurate, so I’m not sure what changed, but the plugin is set to auto-update.
    Please let me know the next steps, otherwise I will disable the plugin.
    Thank you
    #154348
    Elana
    If you haven’t already, please ensure you’re using version 1.16.10 of Total Upkeep, as this version should resolve the issue with excessive emails.
    If you’re already on this version and are still experiencing issues, we can help reset your CRON jobs.
    Steps to reset your Total Upkeep CRON
    1. To check the status of your CRON jobs by going into Total Upkeep -> Tools -> CRON log
    2. If there are no logs then no more emails are queued to send and you no longer need to proceed
    3. Add snippet to WordPress to Reset CRON Jobs Script
    4. Once added go to check status that all CRON jobs are removed from the queue
    5. If they are removed then delete the CRON Jobs Script from step 3. Otherwise no future jobs will run.
    How to add snippet to WordPress.
    • You can use a plugin like Code Snippets.
    • Alternatively, you can add it directly to your theme’s functions.php file by going to Appearance > Theme Editor, selecting Theme Functions on the right, and pasting it after the <?php line.
    Please let me know if you need any further assistance!
    Elana D.
    #154427
    Elana
    Thank you for reaching out to our support team!
    To check the status of your CRON jobs, please go to Total Upkeep -> Tools -> CRON Log. If you don’t see any entries there, you’ll need to remove the script.
    The script is designed to remove the CRON jobs and prevent them from being created. It’s important to delete the script after the jobs have been removed to ensure that your backups continue to work properly.
    If you need further assistance, feel free to reach out. We’re happy to help!
    Elana D.
    #154358
    A Conlon
    Hello Elena,
    1) The Total Upkeep Plugin is up to date and currently at version 1.16.10 on both websites. I have verified this twice.
    2) I added the snippet to the functions.php to one of the websites. The other one does not allow access to the functions.php. I will see if I can gain access to it.
    3) I changed the run date to Saturday for JonKeeyes.com as a test to see if changing the functions.php would have an effect. I also set the Scheduler for every hour, which was the longest space allowed.
    In the meantime, here is a copy of the log:
    [2025-02-26 00:43:43 UTC] PHP Version: 7.4.33
    [2025-02-26 00:43:43 UTC] WordPress Version: 6.7.2
    [2025-02-26 00:43:43 UTC] Total Upkeep version: 1.16.9
    [2025-02-26 00:43:43 UTC] getpgid support: Available
    [2025-02-26 05:03:50 UTC] Adding Job: {
    “filepath”: “\/home\/highlan7\/boldgrid_backup\/boldgrid-backup-www.jonkeeyes.com-64dacc8c-20250226-050026.zip”,
    “action”: “boldgrid_backup_post_jobs_email”,
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “compressor”: “php_zip”,
    “filesize”: 472314293,
    “save”: true,
    “total_size”: 735762546,
    “folder_include”: “WPCORE,\/wp-content”,
    “folder_exclude”: “.git,node_modules,wp-content\/cache”,
    “table_exclude”: [],
    “title”: null,
    “description”: null,
    “ABSPATH”: “\/home\/highlan7\/public_html\/JKWP2\/”,
    “backup_id”: “64dacc8c”,
    “siteurl”: “https:\/\/www.jonkeeyes.com”,
    “timestamp”: 1740546009,
    “gateway_interface”: false,
    “http_host”: “www.jonkeeyes.com”,
    “php_sapi_name”: “litespeed”,
    “php_uname”: “Linux mi3-ls21.a2hosting.com 4.18.0-513.9.1.lve.el7h.x86_64 #1 SMP Mon Dec 4 13:57:13 UTC 2023 x86_64”,
    “php_version”: “7.4.33”,
    “server_addr”: “66.198.240.35”,
    “server_name”: “www.jonkeeyes.com”,
    “server_protocol”: “HTTP\/1.1”,
    “server_software”: “LiteSpeed”,
    “uid”: 1008,
    “username”: “highlan7”,
    “encrypt_db”: false,
    “trigger”: “Cron”,
    “lastmodunix”: 1740546230,
    “duration”: “221.56”,
    “db_duration”: “13.35”,
    “db_filename”: “highlan7_wp576.20250226-050009.sql”
    “post_action”: “delete_all_prior”,
    “status”: “pending”
    [2025-02-26 05:10:04 UTC] Running job: {
    “filepath”: “\/home\/highlan7\/boldgrid_backup\/boldgrid-backup-www.jonkeeyes.com-64dacc8c-20240228-050015.zip”,
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “filesize”: 431302025,
    “save”: true,
    “total_size”: 632663566,
    “folder_exclude”: “.git,node_modules”,
    “title”: null,
    “timestamp”: 1709096408,
    “uid”: 1008,
    “trigger”: “Cron”,
    “lastmodunix”: 1709096830,
    “duration”: “422.32”,
    “db_duration”: “5.31”,
    “db_filename”: “highlan7_wp576.20240228-050008.sql”
    “status”: “pending”
    [2025-02-26 05:10:04 UTC] Deleting Job: {
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “save”: true,
    “title”: null,
    “uid”: 1008,
    “trigger”: “Cron”,
    “status”: “running”,
    “start_time”: 1740546604
    [2025-02-26 05:20:07 UTC] Running job: {
    “filepath”: “\/home\/highlan7\/boldgrid_backup\/boldgrid-backup-www.jonkeeyes.com-64dacc8c-20240306-050020.zip”,
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “filesize”: 430794541,
    “save”: true,
    “total_size”: 631751225,
    “title”: null,
    “timestamp”: 1709701213,
    “uid”: 1008,
    “trigger”: “Cron”,
    “lastmodunix”: 1709701640,
    “duration”: “427.01”,
    “db_duration”: “5.05”,
    “db_filename”: “highlan7_wp576.20240306-050013.sql”
    “status”: “pending”
    [2025-02-26 05:20:07 UTC] Deleting Job: {
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “save”: true,
    “title”: null,
    “uid”: 1008,
    “trigger”: “Cron”,
    “start_time”: 1740547207
    [2025-02-26 05:30:06 UTC] Running job: {
    “filepath”: “\/home\/highlan7\/boldgrid_backup\/boldgrid-backup-www.jonkeeyes.com-64dacc8c-20240313-040014.zip”,
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “filesize”: 430777564,
    “save”: true,
    “total_size”: 631660344,
    “title”: null,
    “timestamp”: 1710302407,
    “uid”: 1008,
    “trigger”: “Cron”,
    “lastmodunix”: 1710302837,
    “duration”: “430.15”,
    “db_duration”: “4.92”,
    “db_filename”: “highlan7_wp576.20240313-040007.sql”
    “status”: “pending”
    [2025-02-26 05:30:06 UTC] Deleting Job: {
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “save”: true,
    “title”: null,
    “uid”: 1008,
    “trigger”: “Cron”,
    “start_time”: 1740547806
    [2025-02-26 05:40:07 UTC] Running job: {
    “filepath”: “\/home\/highlan7\/boldgrid_backup\/boldgrid-backup-www.jonkeeyes.com-64dacc8c-20240320-040020.zip”,
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “filesize”: 430802292,
    “save”: true,
    “total_size”: 631788174,
    “title”: null,
    “timestamp”: 1710907213,
    “uid”: 1008,
    “trigger”: “Cron”,
    “lastmodunix”: 1710907640,
    “duration”: “427.88”,
    “db_duration”: “5.07”,
    “db_filename”: “highlan7_wp576.20240320-040013.sql”
    “status”: “pending”
    [2025-02-26 05:40:07 UTC] Deleting Job: {
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “save”: true,
    “title”: null,
    “uid”: 1008,
    “trigger”: “Cron”,
    “start_time”: 1740548407
    [2025-02-26 05:50:06 UTC] Running job: {
    “filepath”: “\/home\/highlan7\/boldgrid_backup\/boldgrid-backup-www.jonkeeyes.com-64dacc8c-20240327-040023.zip”,
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “filesize”: 431000329,
    “save”: true,
    “total_size”: 632143520,
    “title”: null,
    “timestamp”: 1711512015,
    “uid”: 1008,
    “trigger”: “Cron”,
    “lastmodunix”: 1711512444,
    “duration”: “428.62”,
    “db_duration”: “5.38”,
    “db_filename”: “highlan7_wp576.20240327-040016.sql”
    “status”: “pending”
    [2025-02-26 05:50:06 UTC] Deleting Job: {
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “save”: true,
    “title”: null,
    “uid”: 1008,
    “trigger”: “Cron”,
    “start_time”: 1740549006
    [2025-02-26 06:00:20 UTC] Running job: {
    “filepath”: “\/home\/highlan7\/boldgrid_backup\/boldgrid-backup-www.jonkeeyes.com-64dacc8c-20240403-040015.zip”,
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “filesize”: 431645176,
    “save”: true,
    “total_size”: 634254614,
    “title”: null,
    “timestamp”: 1712116807,
    “uid”: 1008,
    “trigger”: “Cron”,
    “lastmodunix”: 1712117000,
    “duration”: “192.20”,
    “db_duration”: “5.18”,
    “db_filename”: “highlan7_wp576.20240403-040008.sql”
    “status”: “pending”
    [2025-02-26 06:00:20 UTC] Deleting Job: {
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “save”: true,
    “title”: null,
    “uid”: 1008,
    “trigger”: “Cron”,
    “start_time”: 1740549620
    [2025-02-26 06:15:09 UTC] Running job: {
    “filepath”: “\/home\/highlan7\/boldgrid_backup\/boldgrid-backup-www.jonkeeyes.com-64dacc8c-20240410-040015.zip”,
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “filesize”: 431687063,
    “save”: true,
    “total_size”: 634297434,
    “title”: null,
    “timestamp”: 1712721608,
    “uid”: 1008,
    “trigger”: “Cron”,
    “lastmodunix”: 1712722037,
    “duration”: “428.76”,
    “db_duration”: “5.20”,
    “db_filename”: “highlan7_wp576.20240410-040008.sql”
    “status”: “pending”
    [2025-02-26 06:15:14 UTC] Deleting Job: {
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “save”: true,
    “title”: null,
    “uid”: 1008,
    “trigger”: “Cron”,
    “start_time”: 1740550510
    [2025-02-26 06:30:23 UTC] Running job: {
    “filepath”: “\/home\/highlan7\/boldgrid_backup\/boldgrid-backup-www.jonkeeyes.com-64dacc8c-20240417-040014.zip”,
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “filesize”: 431684447,
    “save”: true,
    “total_size”: 634471208,
    “title”: null,
    “timestamp”: 1713326408,
    “uid”: 1008,
    “trigger”: “Cron”,
    “lastmodunix”: 1713326818,
    “duration”: “410.23”,
    “db_filename”: “highlan7_wp576.20240417-040008.sql”
    “status”: “pending”
    [2025-02-26 06:30:23 UTC] Deleting Job: {
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “save”: true,
    “title”: null,
    “uid”: 1008,
    “trigger”: “Cron”,
    “start_time”: 1740551423
    [2025-02-26 06:45:10 UTC] Running job: {
    “filepath”: “\/home\/highlan7\/boldgrid_backup\/boldgrid-backup-www.jonkeeyes.com-64dacc8c-20240424-040018.zip”,
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “filesize”: 431108725,
    “save”: true,
    “total_size”: 632673405,
    “title”: null,
    “timestamp”: 1713931211,
    “uid”: 1008,
    “trigger”: “Cron”,
    “lastmodunix”: 1713931637,
    “duration”: “426.10”,
    “db_filename”: “highlan7_wp576.20240424-040011.sql”
    “status”: “pending”
    [2025-02-26 06:45:10 UTC] Deleting Job: {
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “save”: true,
    “title”: null,
    “uid”: 1008,
    “trigger”: “Cron”,
    “start_time”: 1740552310
    [2025-02-26 07:00:07 UTC] Running job: {
    “filepath”: “\/home\/highlan7\/boldgrid_backup\/boldgrid-backup-www.jonkeeyes.com-64dacc8c-20240501-040018.zip”,
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “filesize”: 431124431,
    “save”: true,
    “total_size”: 632741790,
    “title”: null,
    “timestamp”: 1714536009,
    “uid”: 1008,
    “trigger”: “Cron”,
    “lastmodunix”: 1714536216,
    “duration”: “206.43”,
    “db_duration”: “5.16”,
    “db_filename”: “highlan7_wp576.20240501-040009.sql”
    “status”: “pending”
    [2025-02-26 07:00:07 UTC] Deleting Job: {
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “save”: true,
    “title”: null,
    “uid”: 1008,
    “trigger”: “Cron”,
    “start_time”: 1740553207
    [2025-02-26 07:15:10 UTC] Running job: {
    “filepath”: “\/home\/highlan7\/boldgrid_backup\/boldgrid-backup-www.jonkeeyes.com-64dacc8c-20240508-040018.zip”,
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “filesize”: 431466680,
    “save”: true,
    “total_size”: 633034036,
    “title”: null,
    “timestamp”: 1715140809,
    “uid”: 1008,
    “trigger”: “Cron”,
    “lastmodunix”: 1715141211,
    “duration”: “401.74”,
    “db_duration”: “5.33”,
    “db_filename”: “highlan7_wp576.20240508-040009.sql”
    “status”: “pending”
    [2025-02-26 07:15:10 UTC] Deleting Job: {
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “save”: true,
    “title”: null,
    “uid”: 1008,
    “trigger”: “Cron”,
    “start_time”: 1740554110
    [2025-02-26 07:30:06 UTC] Running job: {
    “filepath”: “\/home\/highlan7\/boldgrid_backup\/boldgrid-backup-www.jonkeeyes.com-64dacc8c-20240515-040030.zip”,
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “filesize”: 431694950,
    “save”: true,
    “total_size”: 633474287,
    “title”: null,
    “timestamp”: 1715745618,
    “uid”: 1008,
    “trigger”: “Cron”,
    “lastmodunix”: 1715745908,
    “duration”: “289.65”,
    “db_duration”: “7.95”,
    “db_filename”: “highlan7_wp576.20240515-040018.sql”
    “status”: “pending”
    [2025-02-26 07:30:06 UTC] Deleting Job: {
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “save”: true,
    “title”: null,
    “uid”: 1008,
    “trigger”: “Cron”,
    “start_time”: 1740555006
    [2025-02-26 07:45:09 UTC] Running job: {
    “filepath”: “\/home\/highlan7\/boldgrid_backup\/boldgrid-backup-www.jonkeeyes.com-64dacc8c-20240522-040018.zip”,
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “filesize”: 431733283,
    “save”: true,
    “total_size”: 633762975,
    “title”: null,
    “timestamp”: 1716350408,
    “uid”: 1008,
    “trigger”: “Cron”,
    “lastmodunix”: 1716350720,
    “duration”: “311.92”,
    “db_duration”: “5.25”,
    “db_filename”: “highlan7_wp576.20240522-040009.sql”
    “status”: “pending”
    [2025-02-26 07:45:09 UTC] Deleting Job: {
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “save”: true,
    “title”: null,
    “uid”: 1008,
    “trigger”: “Cron”,
    “start_time”: 1740555909
    [2025-02-26 08:00:08 UTC] Running job: {
    “filepath”: “\/home\/highlan7\/boldgrid_backup\/boldgrid-backup-www.jonkeeyes.com-64dacc8c-20240529-040023.zip”,
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “filesize”: 431739529,
    “save”: true,
    “total_size”: 633186576,
    “title”: null,
    “timestamp”: 1716955213,
    “uid”: 1008,
    “trigger”: “Cron”,
    “lastmodunix”: 1716955628,
    “duration”: “414.44”,
    “db_duration”: “5.02”,
    “db_filename”: “highlan7_wp576.20240529-040013.sql”
    “status”: “pending”
    [2025-02-26 08:00:08 UTC] Deleting Job: {
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “save”: true,
    “title”: null,
    “uid”: 1008,
    “trigger”: “Cron”,
    “start_time”: 1740556808
    [2025-02-26 08:15:07 UTC] Running job: {
    “filepath”: “\/home\/highlan7\/boldgrid_backup\/boldgrid-backup-www.jonkeeyes.com-64dacc8c-20240605-040018.zip”,
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “filesize”: 431842597,
    “save”: true,
    “total_size”: 633740624,
    “title”: null,
    “timestamp”: 1717560009,
    “uid”: 1008,
    “trigger”: “Cron”,
    “lastmodunix”: 1717560439,
    “duration”: “429.80”,
    “db_duration”: “5.40”,
    “db_filename”: “highlan7_wp576.20240605-040009.sql”
    “status”: “pending”
    [2025-02-26 08:15:07 UTC] Deleting Job: {
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “save”: true,
    “title”: null,
    “uid”: 1008,
    “trigger”: “Cron”,
    “start_time”: 1740557707
    [2025-02-26 08:30:06 UTC] Running job: {
    “filepath”: “\/home\/highlan7\/boldgrid_backup\/boldgrid-backup-www.jonkeeyes.com-64dacc8c-20240612-040016.zip”,
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “filesize”: 430288018,
    “save”: true,
    “total_size”: 628992845,
    “title”: null,
    “timestamp”: 1718164807,
    “uid”: 1008,
    “trigger”: “Cron”,
    “lastmodunix”: 1718165225,
    “duration”: “418.04”,
    “db_filename”: “highlan7_wp576.20240612-040007.sql”
    “status”: “pending”
    [2025-02-26 08:30:06 UTC] Deleting Job: {
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “save”: true,
    “title”: null,
    “uid”: 1008,
    “trigger”: “Cron”,
    “start_time”: 1740558606
    [2025-02-26 08:45:06 UTC] Running job: {
    “filepath”: “\/home\/highlan7\/boldgrid_backup\/boldgrid-backup-www.jonkeeyes.com-64dacc8c-20240619-040017.zip”,
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “filesize”: 430238599,
    “save”: true,
    “total_size”: 628786504,
    “title”: null,
    “timestamp”: 1718769607,
    “uid”: 1008,
    “trigger”: “Cron”,
    “lastmodunix”: 1718770035,
    “duration”: “427.89”,
    “db_duration”: “5.46”,
    “db_filename”: “highlan7_wp576.20240619-040007.sql”
    “status”: “pending”
    [2025-02-26 08:45:06 UTC] Deleting Job: {
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “save”: true,
    “title”: null,
    “uid”: 1008,
    “trigger”: “Cron”,
    “start_time”: 1740559506
    [2025-02-26 09:00:09 UTC] Running job: {
    “filepath”: “\/home\/highlan7\/boldgrid_backup\/boldgrid-backup-www.jonkeeyes.com-64dacc8c-20240703-040022.zip”,
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “filesize”: 451333313,
    “save”: true,
    “total_size”: 699730742,
    “title”: null,
    “timestamp”: 1719979212,
    “uid”: 1008,
    “trigger”: “Cron”,
    “lastmodunix”: 1719979677,
    “duration”: “464.90”,
    “db_duration”: “5.54”,
    “db_filename”: “highlan7_wp576.20240703-040012.sql”
    “status”: “pending”
    [2025-02-26 09:00:09 UTC] Deleting Job: {
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “save”: true,
    “title”: null,
    “uid”: 1008,
    “trigger”: “Cron”,
    “start_time”: 1740560409
    [2025-02-26 09:15:08 UTC] Running job: {
    “filepath”: “\/home\/highlan7\/boldgrid_backup\/boldgrid-backup-www.jonkeeyes.com-64dacc8c-20240710-040022.zip”,
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “filesize”: 451365392,
    “save”: true,
    “total_size”: 699841842,
    “title”: null,
    “timestamp”: 1720584012,
    “uid”: 1008,
    “trigger”: “Cron”,
    “lastmodunix”: 1720584477,
    “duration”: “465.08”,
    “db_duration”: “5.78”,
    “db_filename”: “highlan7_wp576.20240710-040012.sql”
    “status”: “pending”
    [2025-02-26 09:15:08 UTC] Deleting Job: {
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “save”: true,
    “title”: null,
    “uid”: 1008,
    “trigger”: “Cron”,
    “start_time”: 1740561308
    [2025-02-26 09:30:05 UTC] Running job: {
    “filepath”: “\/home\/highlan7\/boldgrid_backup\/boldgrid-backup-www.jonkeeyes.com-64dacc8c-20240717-040025.zip”,
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “filesize”: 433737371,
    “save”: true,
    “total_size”: 649143602,
    “title”: null,
    “timestamp”: 1721188816,
    “uid”: 1008,
    “trigger”: “Cron”,
    “lastmodunix”: 1721189002,
    “duration”: “185.94”,
    “db_duration”: “5.87”,
    “db_filename”: “highlan7_wp576.20240717-040016.sql”
    “status”: “pending”
    [2025-02-26 09:30:05 UTC] Deleting Job: {
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “save”: true,
    “title”: null,
    “uid”: 1008,
    “trigger”: “Cron”,
    “start_time”: 1740562205
    [2025-02-26 09:45:07 UTC] Running job: {
    “filepath”: “\/home\/highlan7\/boldgrid_backup\/boldgrid-backup-www.jonkeeyes.com-64dacc8c-20240724-040031.zip”,
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “filesize”: 432774445,
    “save”: true,
    “total_size”: 646561777,
    “title”: null,
    “timestamp”: 1721793616,
    “uid”: 1008,
    “trigger”: “Cron”,
    “lastmodunix”: 1721794008,
    “duration”: “390.64”,
    “db_duration”: “9.59”,
    “db_filename”: “highlan7_wp576.20240724-040017.sql”
    “status”: “pending”
    [2025-02-26 09:45:07 UTC] Deleting Job: {
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “save”: true,
    “title”: null,
    “uid”: 1008,
    “trigger”: “Cron”,
    “start_time”: 1740563107
    [2025-02-26 10:00:09 UTC] Running job: {
    “filepath”: “\/home\/highlan7\/boldgrid_backup\/boldgrid-backup-www.jonkeeyes.com-64dacc8c-20240807-040019.zip”,
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “filesize”: 430807031,
    “save”: true,
    “total_size”: 644966236,
    “title”: null,
    “timestamp”: 1723003210,
    “uid”: 1008,
    “trigger”: “Cron”,
    “lastmodunix”: 1723003431,
    “duration”: “221.62”,
    “db_duration”: “5.66”,
    “db_filename”: “highlan7_wp576.20240807-040010.sql”
    “status”: “pending”
    [2025-02-26 10:00:09 UTC] Deleting Job: {
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “save”: true,
    “title”: null,
    “uid”: 1008,
    “trigger”: “Cron”,
    “start_time”: 1740564009
    [2025-02-26 10:15:03 UTC] Running job: {
    “filepath”: “\/home\/highlan7\/boldgrid_backup\/boldgrid-backup-www.jonkeeyes.com-64dacc8c-20240814-040016.zip”,
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “filesize”: 430870667,
    “save”: true,
    “total_size”: 645268838,
    “title”: null,
    “timestamp”: 1723608005,
    “uid”: 1008,
    “trigger”: “Cron”,
    “lastmodunix”: 1723608441,
    “duration”: “435.87”,
    “db_filename”: “highlan7_wp576.20240814-040006.sql”
    “status”: “pending”
    [2025-02-26 10:15:03 UTC] Deleting Job: {
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “save”: true,
    “title”: null,
    “uid”: 1008,
    “trigger”: “Cron”,
    “start_time”: 1740564903
    [2025-02-26 10:30:10 UTC] Running job: {
    “filepath”: “\/home\/highlan7\/boldgrid_backup\/boldgrid-backup-www.jonkeeyes.com-64dacc8c-20240821-040022.zip”,
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “filesize”: 443339918,
    “save”: true,
    “total_size”: 675764650,
    “title”: null,
    “timestamp”: 1724212812,
    “uid”: 1008,
    “trigger”: “Cron”,
    “lastmodunix”: 1724213170,
    “duration”: “357.50”,
    “db_duration”: “6.17”,
    “db_filename”: “highlan7_wp576.20240821-040012.sql”
    “status”: “pending”
    [2025-02-26 10:30:10 UTC] Deleting Job: {
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “save”: true,
    “title”: null,
    “uid”: 1008,
    “trigger”: “Cron”,
    “start_time”: 1740565810
    [2025-02-26 10:45:07 UTC] Running job: {
    “filepath”: “\/home\/highlan7\/boldgrid_backup\/boldgrid-backup-www.jonkeeyes.com-64dacc8c-20240828-040021.zip”,
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “filesize”: 452662399,
    “save”: true,
    “total_size”: 701928812,
    “title”: null,
    “timestamp”: 1724817604,
    “uid”: 1008,
    “trigger”: “Cron”,
    “lastmodunix”: 1724817885,
    “duration”: “280.78”,
    “db_duration”: “12.99”,
    “db_filename”: “highlan7_wp576.20240828-040004.sql”
    “status”: “pending”
    [2025-02-26 10:45:07 UTC] Deleting Job: {
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “save”: true,
    “title”: null,
    “uid”: 1008,
    “trigger”: “Cron”,
    “start_time”: 1740566707
    [2025-02-26 11:00:10 UTC] Running job: {
    “filepath”: “\/home\/highlan7\/boldgrid_backup\/boldgrid-backup-www.jonkeeyes.com-64dacc8c-20240904-040027.zip”,
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “filesize”: 452600114,
    “save”: true,
    “total_size”: 701570210,
    “title”: null,
    “timestamp”: 1725422410,
    “uid”: 1008,
    “trigger”: “Cron”,
    “lastmodunix”: 1725422858,
    “duration”: “447.07”,
    “db_duration”: “12.61”,
    “db_filename”: “highlan7_wp576.20240904-040011.sql”
    “status”: “pending”
    [2025-02-26 11:00:10 UTC] Deleting Job: {
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “save”: true,
    “title”: null,
    “uid”: 1008,
    “trigger”: “Cron”,
    “start_time”: 1740567610
    [2025-02-26 11:15:06 UTC] Running job: {
    “filepath”: “\/home\/highlan7\/boldgrid_backup\/boldgrid-backup-www.jonkeeyes.com-64dacc8c-20240911-040026.zip”,
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “filesize”: 451801629,
    “save”: true,
    “total_size”: 701065789,
    “title”: null,
    “timestamp”: 1726027209,
    “uid”: 1008,
    “trigger”: “Cron”,
    “lastmodunix”: 1726027417,
    “duration”: “208.30”,
    “db_duration”: “12.76”,
    “db_filename”: “highlan7_wp576.20240911-040009.sql”
    “status”: “pending”
    [2025-02-26 11:15:06 UTC] Deleting Job: {
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “save”: true,
    “title”: null,
    “uid”: 1008,
    “trigger”: “Cron”,
    “start_time”: 1740568506
    [2025-02-26 11:30:08 UTC] Running job: {
    “filepath”: “\/home\/highlan7\/boldgrid_backup\/boldgrid-backup-www.jonkeeyes.com-64dacc8c-20240918-040026.zip”,
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “filesize”: 452160140,
    “save”: true,
    “total_size”: 702508286,
    “title”: null,
    “timestamp”: 1726632009,
    “uid”: 1008,
    “trigger”: “Cron”,
    “lastmodunix”: 1726632469,
    “duration”: “460.19”,
    “db_duration”: “12.87”,
    “db_filename”: “highlan7_wp576.20240918-040009.sql”
    “status”: “pending”
    [2025-02-26 11:30:08 UTC] Deleting Job: {
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “save”: true,
    “title”: null,
    “uid”: 1008,
    “trigger”: “Cron”,
    “start_time”: 1740569408
    [2025-02-26 11:45:08 UTC] Running job: {
    “filepath”: “\/home\/highlan7\/boldgrid_backup\/boldgrid-backup-www.jonkeeyes.com-64dacc8c-20240925-040024.zip”,
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “filesize”: 452009920,
    “save”: true,
    “total_size”: 702139798,
    “title”: null,
    “timestamp”: 1727236807,
    “uid”: 1008,
    “trigger”: “Cron”,
    “lastmodunix”: 1727237012,
    “duration”: “205.26”,
    “db_duration”: “12.70”,
    “db_filename”: “highlan7_wp576.20240925-040007.sql”
    “status”: “pending”
    [2025-02-26 11:45:08 UTC] Deleting Job: {
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “save”: true,
    “title”: null,
    “uid”: 1008,
    “trigger”: “Cron”,
    “start_time”: 1740570308
    [2025-02-26 12:00:07 UTC] Running job: {
    “filepath”: “\/home\/highlan7\/boldgrid_backup\/boldgrid-backup-www.jonkeeyes.com-64dacc8c-20241002-040027.zip”,
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “filesize”: 451641005,
    “save”: true,
    “total_size”: 701260481,
    “title”: null,
    “timestamp”: 1727841610,
    “uid”: 1008,
    “trigger”: “Cron”,
    “lastmodunix”: 1727841909,
    “duration”: “299.39”,
    “db_duration”: “12.71”,
    “db_filename”: “highlan7_wp576.20241002-040010.sql”
    “status”: “pending”
    [2025-02-26 12:00:07 UTC] Deleting Job: {
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “save”: true,
    “title”: null,
    “uid”: 1008,
    “trigger”: “Cron”,
    “start_time”: 1740571207
    [2025-02-26 12:15:08 UTC] Running job: {
    “filepath”: “\/home\/highlan7\/boldgrid_backup\/boldgrid-backup-www.jonkeeyes.com-64dacc8c-20241009-040026.zip”,
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “filesize”: 451761823,
    “save”: true,
    “total_size”: 701448915,
    “title”: null,
    “timestamp”: 1728446409,
    “uid”: 1008,
    “trigger”: “Cron”,
    “lastmodunix”: 1728446865,
    “duration”: “455.71”,
    “db_duration”: “12.95”,
    “db_filename”: “highlan7_wp576.20241009-040009.sql”
    “status”: “pending”
    [2025-02-26 12:15:08 UTC] Deleting Job: {
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “save”: true,
    “title”: null,
    “uid”: 1008,
    “trigger”: “Cron”,
    “start_time”: 1740572108
    [2025-02-26 12:30:08 UTC] Running job: {
    “filepath”: “\/home\/highlan7\/boldgrid_backup\/boldgrid-backup-www.jonkeeyes.com-64dacc8c-20241016-040029.zip”,
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “filesize”: 451776229,
    “save”: true,
    “total_size”: 701524065,
    “title”: null,
    “timestamp”: 1729051212,
    “uid”: 1008,
    “trigger”: “Cron”,
    “lastmodunix”: 1729051671,
    “duration”: “459.26”,
    “db_duration”: “12.89”,
    “db_filename”: “highlan7_wp576.20241016-040012.sql”
    “status”: “pending”
    [2025-02-26 12:30:08 UTC] Deleting Job: {
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “save”: true,
    “title”: null,
    “uid”: 1008,
    “trigger”: “Cron”,
    “start_time”: 1740573008
    [2025-02-26 12:45:06 UTC] Running job: {
    “filepath”: “\/home\/highlan7\/boldgrid_backup\/boldgrid-backup-www.jonkeeyes.com-64dacc8c-20241023-040027.zip”,
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “filesize”: 452823764,
    “save”: true,
    “total_size”: 702748570,
    “title”: null,
    “timestamp”: 1729656010,
    “uid”: 1008,
    “trigger”: “Cron”,
    “lastmodunix”: 1729656454,
    “duration”: “443.96”,
    “db_duration”: “12.73”,
    “db_filename”: “highlan7_wp576.20241023-040010.sql”
    “status”: “pending”
    [2025-02-26 12:45:06 UTC] Deleting Job: {
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “save”: true,
    “title”: null,
    “uid”: 1008,
    “trigger”: “Cron”,
    “start_time”: 1740573906
    [2025-02-26 13:00:11 UTC] Running job: {
    “filepath”: “\/home\/highlan7\/boldgrid_backup\/boldgrid-backup-www.jonkeeyes.com-64dacc8c-20241106-050025.zip”,
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “filesize”: 452995287,
    “save”: true,
    “total_size”: 703383777,
    “title”: null,
    “timestamp”: 1730869208,
    “uid”: 1008,
    “trigger”: “Cron”,
    “lastmodunix”: 1730869619,
    “duration”: “411.94”,
    “db_duration”: “13.11”,
    “db_filename”: “highlan7_wp576.20241106-050008.sql”
    “status”: “pending”
    [2025-02-26 13:00:11 UTC] Deleting Job: {
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “save”: true,
    “title”: null,
    “uid”: 1008,
    “trigger”: “Cron”,
    “start_time”: 1740574811
    [2025-02-26 13:15:05 UTC] Running job: {
    “filepath”: “\/home\/highlan7\/boldgrid_backup\/boldgrid-backup-www.jonkeeyes.com-64dacc8c-20241113-050025.zip”,
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “filesize”: 453557610,
    “save”: true,
    “total_size”: 705452337,
    “title”: null,
    “timestamp”: 1731474007,
    “uid”: 1008,
    “trigger”: “Cron”,
    “lastmodunix”: 1731474460,
    “duration”: “452.62”,
    “db_duration”: “13.06”,
    “db_filename”: “highlan7_wp576.20241113-050007.sql”
    “status”: “pending”
    [2025-02-26 13:15:05 UTC] Deleting Job: {
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “save”: true,
    “title”: null,
    “uid”: 1008,
    “trigger”: “Cron”,
    “start_time”: 1740575705
    [2025-02-26 13:30:10 UTC] Running job: {
    “filepath”: “\/home\/highlan7\/boldgrid_backup\/boldgrid-backup-www.jonkeeyes.com-64dacc8c-20241120-050027.zip”,
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “filesize”: 463371330,
    “save”: true,
    “total_size”: 718486176,
    “title”: null,
    “timestamp”: 1732078810,
    “uid”: 1008,
    “trigger”: “Cron”,
    “lastmodunix”: 1732079285,
    “duration”: “474.82”,
    “db_duration”: “13.19”,
    “db_filename”: “highlan7_wp576.20241120-050010.sql”
    “status”: “pending”
    [2025-02-26 13:30:10 UTC] Deleting Job: {
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “save”: true,
    “title”: null,
    “uid”: 1008,
    “trigger”: “Cron”,
    “start_time”: 1740576610
    [2025-02-26 13:45:07 UTC] Running job: {
    “filepath”: “\/home\/highlan7\/boldgrid_backup\/boldgrid-backup-www.jonkeeyes.com-64dacc8c-20241127-050026.zip”,
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “filesize”: 463850415,
    “save”: true,
    “total_size”: 719680104,
    “title”: null,
    “timestamp”: 1732683609,
    “uid”: 1008,
    “trigger”: “Cron”,
    “lastmodunix”: 1732683959,
    “duration”: “350.32”,
    “db_duration”: “13.31”,
    “db_filename”: “highlan7_wp576.20241127-050009.sql”
    “status”: “pending”
    [2025-02-26 13:45:07 UTC] Deleting Job: {
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “save”: true,
    “title”: null,
    “uid”: 1008,
    “trigger”: “Cron”,
    “start_time”: 1740577507
    [2025-02-26 14:00:07 UTC] Running job: {
    “filepath”: “\/home\/highlan7\/boldgrid_backup\/boldgrid-backup-www.jonkeeyes.com-64dacc8c-20241204-050022.zip”,
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “filesize”: 465001562,
    “save”: true,
    “total_size”: 721161624,
    “title”: null,
    “timestamp”: 1733288405,
    “uid”: 1008,
    “trigger”: “Cron”,
    “lastmodunix”: 1733288857,
    “duration”: “452.73”,
    “db_duration”: “13.44”,
    “db_filename”: “highlan7_wp576.20241204-050005.sql”
    “status”: “pending”
    [2025-02-26 14:00:07 UTC] Deleting Job: {
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “save”: true,
    “title”: null,
    “uid”: 1008,
    “trigger”: “Cron”,
    “start_time”: 1740578407
    [2025-02-26 14:15:07 UTC] Running job: {
    “filepath”: “\/home\/highlan7\/boldgrid_backup\/boldgrid-backup-www.jonkeeyes.com-64dacc8c-20241211-050029.zip”,
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “filesize”: 465249273,
    “save”: true,
    “total_size”: 722904211,
    “title”: null,
    “timestamp”: 1733893211,
    “uid”: 1008,
    “trigger”: “Cron”,
    “lastmodunix”: 1733893662,
    “duration”: “451.19”,
    “db_duration”: “13.34”,
    “db_filename”: “highlan7_wp576.20241211-050011.sql”
    “status”: “pending”
    [2025-02-26 14:15:07 UTC] Deleting Job: {
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “save”: true,
    “title”: null,
    “uid”: 1008,
    “trigger”: “Cron”,
    “start_time”: 1740579307
    [2025-02-26 14:30:06 UTC] Running job: {
    “filepath”: “\/home\/highlan7\/boldgrid_backup\/boldgrid-backup-www.jonkeeyes.com-64dacc8c-20241218-050039.zip”,
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “filesize”: 465269292,
    “save”: true,
    “total_size”: 722921891,
    “title”: null,
    “timestamp”: 1734498022,
    “uid”: 1008,
    “trigger”: “Cron”,
    “lastmodunix”: 1734498235,
    “duration”: “213.53”,
    “db_filename”: “highlan7_wp576.20241218-050022.sql”
    “status”: “pending”
    [2025-02-26 14:30:06 UTC] Deleting Job: {
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “save”: true,
    “title”: null,
    “uid”: 1008,
    “trigger”: “Cron”,
    “start_time”: 1740580206
    [2025-02-26 14:45:10 UTC] Running job: {
    “filepath”: “\/home\/highlan7\/boldgrid_backup\/boldgrid-backup-www.jonkeeyes.com-64dacc8c-20241225-050026.zip”,
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “filesize”: 470459599,
    “save”: true,
    “total_size”: 729487535,
    “title”: null,
    “timestamp”: 1735102809,
    “uid”: 1008,
    “trigger”: “Cron”,
    “lastmodunix”: 1735103291,
    “duration”: “481.92”,
    “db_duration”: “13.07”,
    “db_filename”: “highlan7_wp576.20241225-050009.sql”
    “status”: “pending”
    [2025-02-26 14:45:10 UTC] Deleting Job: {
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “save”: true,
    “title”: null,
    “uid”: 1008,
    “trigger”: “Cron”,
    “start_time”: 1740581110
    [2025-02-26 15:00:08 UTC] Running job: {
    “filepath”: “\/home\/highlan7\/boldgrid_backup\/boldgrid-backup-www.jonkeeyes.com-64dacc8c-20250101-050027.zip”,
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “filesize”: 470444753,
    “save”: true,
    “total_size”: 729390487,
    “title”: null,
    “timestamp”: 1735707609,
    “uid”: 1008,
    “trigger”: “Cron”,
    “lastmodunix”: 1735708092,
    “duration”: “483.48”,
    “db_duration”: “13.32”,
    “db_filename”: “highlan7_wp576.20250101-050009.sql”
    “status”: “pending”
    [2025-02-26 15:00:08 UTC] Deleting Job: {
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “save”: true,
    “title”: null,
    “uid”: 1008,
    “trigger”: “Cron”,
    “start_time”: 1740582008
    [2025-02-26 15:15:05 UTC] Running job: {
    “filepath”: “\/home\/highlan7\/boldgrid_backup\/boldgrid-backup-www.jonkeeyes.com-64dacc8c-20250108-050026.zip”,
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “filesize”: 470619061,
    “save”: true,
    “total_size”: 730026830,
    “title”: null,
    “timestamp”: 1736312408,
    “uid”: 1008,
    “trigger”: “Cron”,
    “lastmodunix”: 1736312643,
    “duration”: “235.29”,
    “db_duration”: “13.22”,
    “db_filename”: “highlan7_wp576.20250108-050008.sql”
    “status”: “pending”
    [2025-02-26 15:15:05 UTC] Deleting Job: {
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “save”: true,
    “title”: null,
    “uid”: 1008,
    “trigger”: “Cron”,
    “start_time”: 1740582905
    [2025-02-26 15:30:16 UTC] Running job: {
    “filepath”: “\/home\/highlan7\/boldgrid_backup\/boldgrid-backup-www.jonkeeyes.com-64dacc8c-20250115-050029.zip”,
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “filesize”: 470638432,
    “save”: true,
    “total_size”: 730145656,
    “title”: null,
    “timestamp”: 1736917211,
    “uid”: 1008,
    “trigger”: “Cron”,
    “lastmodunix”: 1736917693,
    “duration”: “481.42”,
    “db_duration”: “13.50”,
    “db_filename”: “highlan7_wp576.20250115-050011.sql”
    “status”: “pending”
    [2025-02-26 15:30:16 UTC] Deleting Job: {
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “save”: true,
    “title”: null,
    “uid”: 1008,
    “trigger”: “Cron”,
    “start_time”: 1740583816
    [2025-02-26 15:45:06 UTC] Running job: {
    “filepath”: “\/home\/highlan7\/boldgrid_backup\/boldgrid-backup-www.jonkeeyes.com-64dacc8c-20250122-050035.zip”,
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “filesize”: 470750033,
    “save”: true,
    “total_size”: 730662739,
    “title”: null,
    “timestamp”: 1737522017,
    “uid”: 1008,
    “trigger”: “Cron”,
    “lastmodunix”: 1737522464,
    “duration”: “446.64”,
    “db_duration”: “13.13”,
    “db_filename”: “highlan7_wp576.20250122-050017.sql”
    “status”: “pending”
    [2025-02-26 15:45:06 UTC] Deleting Job: {
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “save”: true,
    “title”: null,
    “uid”: 1008,
    “trigger”: “Cron”,
    “start_time”: 1740584706
    [2025-02-26 16:00:08 UTC] Running job: {
    “filepath”: “\/home\/highlan7\/boldgrid_backup\/boldgrid-backup-www.jonkeeyes.com-64dacc8c-20250129-050028.zip”,
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “filesize”: 471025985,
    “save”: true,
    “total_size”: 731171649,
    “title”: null,
    “timestamp”: 1738126811,
    “uid”: 1008,
    “trigger”: “Cron”,
    “lastmodunix”: 1738127090,
    “duration”: “278.83”,
    “db_filename”: “highlan7_wp576.20250129-050011.sql”
    “status”: “pending”
    [2025-02-26 16:00:08 UTC] Deleting Job: {
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “save”: true,
    “title”: null,
    “uid”: 1008,
    “trigger”: “Cron”,
    “start_time”: 1740585608
    [2025-02-26 16:15:06 UTC] Running job: {
    “filepath”: “\/home\/highlan7\/boldgrid_backup\/boldgrid-backup-www.jonkeeyes.com-64dacc8c-20250205-050027.zip”,
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “filesize”: 472555537,
    “save”: true,
    “total_size”: 735100091,
    “title”: null,
    “timestamp”: 1738731608,
    “uid”: 1008,
    “trigger”: “Cron”,
    “lastmodunix”: 1738731850,
    “duration”: “241.79”,
    “db_duration”: “14.86”,
    “db_filename”: “highlan7_wp576.20250205-050008.sql”
    “status”: “pending”
    [2025-02-26 16:15:06 UTC] Deleting Job: {
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “save”: true,
    “title”: null,
    “uid”: 1008,
    “trigger”: “Cron”,
    “start_time”: 1740586506
    [2025-02-26 16:30:14 UTC] Running job: {
    “filepath”: “\/home\/highlan7\/boldgrid_backup\/boldgrid-backup-www.jonkeeyes.com-64dacc8c-20250212-050028.zip”,
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “filesize”: 472564478,
    “save”: true,
    “total_size”: 735144215,
    “title”: null,
    “timestamp”: 1739336411,
    “uid”: 1008,
    “trigger”: “Cron”,
    “lastmodunix”: 1739336895,
    “duration”: “484.14”,
    “db_filename”: “highlan7_wp576.20250212-050011.sql”
    “status”: “pending”
    [2025-02-26 16:30:14 UTC] Deleting Job: {
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “save”: true,
    “title”: null,
    “uid”: 1008,
    “trigger”: “Cron”,
    “start_time”: 1740587414
    [2025-02-26 16:45:06 UTC] Running job: {
    “filepath”: “\/home\/highlan7\/boldgrid_backup\/boldgrid-backup-www.jonkeeyes.com-64dacc8c-20250219-050035.zip”,
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “filesize”: 472271115,
    “save”: true,
    “total_size”: 735572222,
    “title”: null,
    “timestamp”: 1739941217,
    “uid”: 1008,
    “trigger”: “Cron”,
    “lastmodunix”: 1739941701,
    “duration”: “484.16”,
    “db_duration”: “13.51”,
    “db_filename”: “highlan7_wp576.20250219-050017.sql”
    “status”: “pending”
    [2025-02-26 16:45:06 UTC] Deleting Job: {
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “save”: true,
    “title”: null,
    “uid”: 1008,
    “trigger”: “Cron”,
    “start_time”: 1740588306
    [2025-02-26 17:00:10 UTC] Running job: {
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “save”: true,
    “title”: null,
    “uid”: 1008,
    “trigger”: “Cron”,
    “status”: “pending”
    [2025-02-26 17:00:10 UTC] Deleting Job: {
    “action_data”: {
    “mode”: “backup”,
    “dryrun”: false,
    “save”: true,
    “title”: null,
    “uid”: 1008,
    “trigger”: “Cron”,
    “start_time”: 1740589210
  • The topic ‘Total Upkeep backup archive running every 10 minutes’ is closed to new replies.
