[Resolved] Using Premium Connect Key Posted on January 8, 2021 by Topic Resolution: ResolvedViewing 3 posts - 1 through 3 (of 3 total)AuthorPosts January 8, 2021 at 3:10 pm #32838 JC ConradGuestHi. We have just purchased a Premium Connect Key with the BoldGrid Connect Key [redacted].Do I need to deactivate and remove the existing plugin and then reinstall the “premium” plugin.Thanks in advance.JC Conrad January 8, 2021 at 3:11 pm #32843 Jesse OwensKeymasterHello JC-You won’t need to deactivate any plugins to upgrade your key. Simply navigate to Settings > BoldGrid Connect and you’ll be able to change your key.To use the premium functionality, make sure you have both the free existing plugin and the premium add-on active. January 8, 2021 at 3:42 pm #32844 JC ConradGuestThanks AuthorPosts Viewing 3 posts - 1 through 3 (of 3 total) The topic ‘[Resolved] Using Premium Connect Key’ is closed to new replies.Post navigationWill BoldGrid Work on my wordpress.com Site? →
