- October 29, 2020 at 5:09 pm #28703
Julita
GuestHey, I installed yesterday your W3 Total Cache plugin and today saw that when I try to edit any product on my e-commerce, it gives me a HTTP 500 problem. After uninstalling plugin, product will open to edit, BUT there is no visible text nor photos. Also my media library changed totally…
How can I fix this problem??!! Can you fix it??! I need my web to work properly to keep on adding products to my e-commerce…Thanks!
October 29, 2020 at 5:46 pm #28712Jesse Owens
KeymasterHi Julita-
Generally speaking, W3 Total Cache shouldn’t interfere with your media library or editing screens, especially once it’s been deactivated and uninstalled.
If possible, can you enable WordPress Debug Logging and let us know what the 500 error was?
There are a couple of steps you can take to make sure the uninstall process was cleanly finished.
First, delete the wp-content/cache directory and make sure that the wp-content/plugins/w3-total-cache directory was deleted when you uninstalled the plugin.
Then, check your .htaccess file for any remnants that might not have been deleted. Look for any code that starts with # BEGIN W3TC (feature) and ends with # END W3TC (feature) and remove the lines in between.
- The topic ‘W3 Total Cache 500 error editing products, media library changed’ is closed to new replies.
