- January 8, 2024 at 12:44 pm #121960
Brian Lee
GuestI work for a non-profit with 12 WordPress websites and I have a few questions.
Does the DB Cluster feature currently work? Some customers have reported issues recently in the forum.
Each website has production, preprod, and dev instances. Would a Pro Subscription be required for the preprod and dev instances?
Do you have a discount for non-profits?Thanks,
Brian
January 8, 2024 at 12:53 pm #122458Marko Vasiljevic
KeymasterHello Brian,
The DB Cluster option in W3 Total Cache is fixed and it’s working as expected when configured. After enabling Pro mode you will find an area inside the Database Cache box on the General Settings page. Click ‘Enable database cluster’ to enable the functionality
As for the licenses, do you need the Pro for all 12 websites?
As for the dev environments, you need to define(‘W3TC_PRO_DEV_MODE’, true) to wp-config.php and resave the license key, and use the same license key on the Prod instance.
Let me know if you have any other questionsJanuary 12, 2024 at 11:53 am #122523Brian Lee
GuestThank you Marko.
Yes, we would need Pro for all 12 sites. I understand you have a bundle discount so 10 sites are 50% of the normal cost. I believe that works out to $495 (bundle) plus $198 (singles) which is $693 per year. Do you have a non-profit discount? Note that we are considering other options and may not go down this path.
Brian
January 12, 2024 at 12:44 pm #122595Marko Vasiljevic
Thank you for your feedback.
I will check more with the finance dept and the management, however, I can say now that we can go with 12 activations for the bulk of 10
If you have any other suggestions, please reach out directly via the plugin in Performance>Support or via the website contact form.
Thanks!January 16, 2024 at 12:07 pm #122783Marko Vasiljevic
Thank you for your patience.
I’ve had a chat with the management and there is no non-profit discount at this time for the bulk activations, however, I can confirm that we can give the 2 extra sites at the same rate of the 10 packThanks!
- The topic ‘W3TC DB Cluster and Pro Sub Discounts’ is closed to new replies.
