- October 21, 2024 at 9:49 am #146426
Filip
So i have next problem. I’m using W3 cache and it works really fine, but some link from the menu are loading fast only after double click. When i click homepage it load super fast, and then when i try to open category from the menu i need to double click to open fast. After that everything works super fast after one click. I hope you could help me.October 21, 2024 at 9:52 am #146565Marko Vasiljevic
KeymasterHello Filip,
I’ve checked your website and it seems that besides other W3 Total Cache, you have more than one caching solution like Cloudflare and a server-side caching: x-dh-cache: HIT
Can you please let me know if you are experiencing the same problem if you temporarily disable the W3 Total Cache?
Thanks! - AuthorPosts
- The topic ‘Wierd problem’ is closed to new replies.
