- June 23, 2017 at 3:13 pm #24143
MemberJust wondering if anyone there has seen or knows where a wiki style format has been set up using the BoldGrid tool. Looking to try to replicate a full-width Wikipedia type of look (Small header area, thin left column, wide center column, and likely a thin right column). I have tried and cannot seem cannot seem to make it work.
I just started using BoldGrid and cannot seem to make it work for side columns. I had tried both MediaWiki and Tiki wikis, but there is just too much of a learning curve to get something set up fairly quickly.
Any assistance, information, and/or direction would be greatly appreciated…
Thanks..Brian
Brian Shelton
C: 804-690-5766
W: osintelnexus.com (eventually on Inmotion Hosting)
June 23, 2017 at 4:59 pm #24144Christopher M
MemberHello Brian,
Thank you for your question about achieving a Wiki look on your BoldGrid site. This may be difficult because the BoldGrid layouts are designed with a business/personal enterprise look, not exactly a wiki type of site.
However, if you would like to let us know what theme you are using, we might be able to make some suggestions or recommend a theme that matches what you’re looking for. Foe example, all of the themes should be able to utilize the WordPress the side bar behavior you see on our site.
Best,
Christopher M.
- The topic ‘Wiki style format using BoldGrid?’ is closed to new replies.
