- October 30, 2023 at 11:27 am #112330
Kristi L Morris
GuestI am struggling to adjust features of the theme I have selected and activated. I used Glaciers from WordPress but it looks like I am working through it with Page and Post Builder (BoldGrid). I am not too far in and would like to start over? Is this possible? Or is there something that I am doing wrong as I cannot seem to make the homepage I am designing look like the theme. The image boxes will not move or scale differently.
October 30, 2023 at 11:58 am #112607Brandon C
ParticipantHi Kristi,
Thanks for reaching out, BoldGrid BoldGrid Post and Page Builder is primarily built to be compatible with the BoldGrid line of themes our latest being Crio Pro WordPress theme. With that being said you do have a lot of flexibility to modify your WordPress themes, including the Glaciers theme that you’ve chosen but you’ll likely need to incorporate your own CSS customizations, which may not display properly in the post and page builder editor.
You can certainly start over at any point. You can reset your WordPress site to its original settings by using a plugin like WP Reset. Please note that this will delete your content and settings so make sure to backup everything you want to keep before proceeding.
If you’re plan is to start over and you still wish to use your Glacier theme, you should contact their support directly and ask theme what page builders they recommend. If you need help starting over with Crio we are right here to answer any further questions you may have.
Thanks Kristi, I hope this helps!
- The topic ‘Working with BoldGrid Post and Page Builder and a third party theme’ is closed to new replies.
