- February 3, 2023 at 12:38 pm #78116Cailin KlessGuest
I’m working on a page for a client– it used to work fine, but since I replaced his photo with a new, the image column seems forever separated from the text column, regardless of how big I make the screen or how small I shrink the photo. In the BoldGrid preview it always looks like they will be side by side, but I update and check what the sight looks live, and on every actual browser it does the photo alone on top and the text below. What is happening / what should I do?
CailinFebruary 3, 2023 at 12:48 pm #78191Brandon CKeymasterHi Cailin,
Thanks for reaching out with your BoldGrid Post and Page Builder questions.
We can definitely help with this but first I want to get a better understanding of what you’re trying to accomplish. When I inspect your page I see that the image is sitting above the content.
If I’m understanding correctly you would like to place two Columns within a Section that would both span 50% of the width of the overall Section.
If this is the case I suggest creating a brand new section and cloning the inner nesting column to create two new columns then replace the content of the two columns with your image and text.
If you’re satisfied at that point you can delete the previously created content and test your changes live.
We have some articles that should help you gain a better understanding of how sections, rows, and columns work in Post and Page builder
– Working with Columns
– Working with Rows
– Working with Sections
– How to use the BoldGrid Post and Page BuilderI hope this helps Cailin, Please let us know if we can assist you further with this!
- The topic ‘Working with columns in Post and Page Builder’ is closed to new replies.
